It is currently Wed Aug 13, 2025 10:30 am
PostPosted: Tue Feb 09, 2010 6:54 pm
What initial hole diameter do you start off with for bridge pin holes? I've been using a 3/16" drill as per instructions in the books I've been following. However, now I am starting to think that this is too large. Last night as I was reaming out some bridge pin holes with a tapered reamer, for the first time, I actually took some measurements of the diameters of the bridge pins I got from Stew-Mac. I did this because I was suspecting that they were sitting down nicely into the holes long before a taper was being formed from top to bottom of the hole. Sure enough, when I measured the bridge pins, the 3/16" diameter point was relatively close to the top of the pin. What this says to me is that, with these pins, only the top of the hole needs to be reamed to get the pin sitting low and further, that there will be a space around the pin and the bottom of the hole. I'm not too fussy about this idea because that means the ball on the end of the strings may be sitting in this space rather than on top of the bridge plate where it's supposed to be.
What say you all to this? Do you start off with a smaller diameter bridge pin hole and do more reaming to ensure a taper from top to bottom of the hole?
PostPosted: Tue Feb 09, 2010 7:15 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
It depends on the small end diameter of the reamer my 5 degree is 1/8 " so I use 5/32", I would rather ream more than have a too large hole. I think that in the old days they didn't ream just drilled so there was no taper in the hole.
Fred
Fred Tellier
PostPosted: Tue Feb 09, 2010 7:21 pm
Size of the string ball end on the diagonal 4.8mm I think.
It still has to fit through whatever your pin size.
PostPosted: Tue Feb 09, 2010 9:10 pm
3/16 the same as martin ,and I can taper the hole to match the pins.
PostPosted: Tue Feb 09, 2010 9:31 pm
I've always started with an 1/8" bit and reamed from there, works with my reamer, but it is on the small end of acceptable.
Greg
Gwaltney Guitars
PostPosted: Tue Feb 09, 2010 9:53 pm
First name: Blain
City: Leander
I drill 3/16 as well and taper to fit.
Some bridge pins require very little reaming so I do it in small slow steps and check it very frequently.
Blain
http://www.ullrichguitar.com
PostPosted: Wed Feb 10, 2010 1:17 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I use 5/32" for a 5 degree pin. Ball end will go through if you slot the bridge& bridgeplate.
Users browsing this forum: johnparchem, Kbore, Ken Lewis and 29 guests
